Cut engine circuit was triggered when i removed/replaced alarm. do not have the factory keyless remote only a copy of the key (bought used). urgent... need car for work. i have tried turining the key in ignition to ACC position 5xs then attempting to start. this has not worked.
Put the battery back and uninstall the alarm, the car shall start.
This is how to reset the alarm Roll up all windows exit the car lock all doors with the remote, then wait ten minutes, unlock the door using the key, that will reset the alarm. without remote I found this, have no idea if it will work, but worth a try!!
Begin with: The driver's door open and unlocked. Key out of the ignition.
1. Insert and remove the key from the ignition switch 2 times within 5 seconds.
NOTE: Steps 2 and 3 should be performed within 40 seconds.
2. Close and open driver's door TWICE.
3. Insert the key into the ignition and remove it.
NOTE: Steps 4 – 6 should be performed within 40 seconds.
4. Close and open the driver's door twice.
5. Insert the key into the ignition.
6. Close the door.
SOURCE: My car alarm is blinking
you can try switching the key to the "on" position then open the hood and disconnect the negative terminal of the battery and reconnect after 2minutes. this will allow the alarm to be '"reset" and will recognize that you have the key for the vehicle.
SOURCE: I have a 2000 toyota avalon ignition problems
Hello I have simular problem the ignition on is stuck in that position with the key turned off and out of the ignition switch.It feels like the key switch is spinning freely in the ignition. Do I need an ignition switch?
SOURCE: 1998 toyota Avalon, the car alarm is going off
put in a new battery and car alarm won't stop sounding..1998 Toyota Avalon
1997or 2007
