SOURCE: Wireless Router Reset
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Have forgotten NetKey password to add laptop to wireless network
Just reset the router and you can configure it again like before.
SOURCE: I am trying to connect
I think you meant the access key password for your wireless security and not the password for the router itself (2 separate passwords).
I'll give you both solutions starting with the wireless key password.
1. access the router configuration page by typing http://192.168.1.1 in your browsr.
2. This should pop up a log in window asking for user name & password
3. The default settings for a linksys router say to leave the username blank and type admin for the password.
4. once you're in look for the Wireless tab and click it then click on wireless security
5. your password will be listed there in the shared key box.
Now if its your router access password that you need you'll need to reset the router if you can't remember it and then follow the steps above to create a wireless security password. Here's how you reset the router. Remember that all custom settings you may have set will be erased and the router will go back to original factory configuration settings
1. On the back of the router you'll find a small hole or indentation and it may or may not have the word reset printed by it.
2. Find a paper clip or something of the same size and use it to press the reset button for about 2-3 seconds
3. Router will be reset
Good luck
SOURCE: I have a linksys wireless router WRT120n, I've
192.168.0.1 from any web page, but before you do that, go to linksys website and see if you cant get default password, they have one just for this purpose, you might have to verify that its yours, but they can give you one that will work
