Question about Pioneer HTD-510 System
How can i increase the bass on pioneer htd-510 without remote
I do not have the remote and i cannot seem to change any sound setting except for standard volume. if there is a way to do this without the remote i would love to know
Posted by carey on
Tony Dugger
    New Friend:
I have tried many different ways gave up don't think you can BUY A REMOTE I DID
Posted on Oct 29, 2013
5 Related Answers
Anonymous
SOURCE: PIONEER HTD-510 DVD RECEIVER NOT WORKING
sound is not working
Posted on May 20, 2008
Anonymous
  • 1990 Answers
SOURCE: OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Posted on Jan 02, 2009
Anonymous
  • 58 Answers
SOURCE: Pioneer DJM500 Mixer - Bass EQ Control on Channel 2
You might want to clean the exisiting potentiometer with dielectric solvent. This might work without having to replace the Pot. But if you have to replace it, make sure you have the correct tools. This is a fine soldering job, but it appears you have the correct part.
Posted on Apr 07, 2009
Anonymous
  • 135 Answers
SOURCE: Pioneer DJM 500 Ch 2 Bass Controller
The bass pot's / controls are notorious for becoming dry jointed, all that is usually needed is the controls resoldering.
http://www.technicsdjuk.com/
Posted on Jul 06, 2010
bshldn
Loretta Northcutt
  • 736 Answers
SOURCE: I'm trying to hook my htd-510 to our toshia Hd and
Without knowing what model Toshiba you have I have to guess that it has an audio output on it. If it does then you connect the audio out on the Toshiba to the TV/VCR in on the Pioneer with a red and white audio RCA cable. Next you do the same for your cable box. Once again not knowing what model cable box I have to make assumptions. Connect your audio output on the cable box to where it says aux IN on the Pioneer with a red and white audio RCA cable.
Posted on Feb 07, 2011
How do i reset the factory volume level on a ge remote monitor xs stereo without the remote?
[PDF]CARESCAPEā„¢ V100 Vital Signs Monitor - GE Healthcare
www3.gehealthcare.com/...monitoring/monitors/gehc-serv...
GE HealthcareNov 21, 2011 - NOTE: The information in this manual applies to CARESCAPE V100 Vital Signs Monitor ...... PULSE VOLUME indicator: flashes to indicate you are making a change to ...... monitor is set to or reverts to factory default settings.
Nov 23, 2015 | GE Televison & Video
My tv keeps accessing menue randomly. will lower volume, change channel etc without any input from me. have changed batteries in remote etc. seems to be internal problem
A few years ago, the Bush and Hitachi standard TV's had this problem. After a long consultaion with the technical bods we put it down to flourecent lamps. That includes energy saving lamps as well. To cure it we fitted a fine wire mesh over the sensor's window inside the set. That reduced the sensitivity enough to stop it.
To prove this, place a piece of black tape over the remote sensor. If it stops then either the remote control is ramdomly transmitting or a light is upsetting it.
If it still does it you have dry joints in or around the sensor.
Hope this helps.
Nov 22, 2010 | Bush Televison & Video
The remote control stopped working on my toshiba flat screen i changed the batteries and only the volume works with the remote still can't turn on/off or change channels
Make sure the mode switch is set correctly for the device (TV, Cable, Video recorder, etc) that you are trying to control.
Apr 28, 2010 | Toshiba CZ36V61 TV
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
The sound control is set at a super low level...To be loud enough to be heard without a problem at a normal distance, the number on the sound level has to be at 90 or 92..My other tv's the same volume is a...
Have you used the remote that came with the TV to raise the volume? Often, when there is more than one remote, one of them is set too low and all you need to do is use the remote that came with the TV to raise the volume level. Good Luck!
Aug 17, 2009 | RCA 14F514T 14" TV
I can't find it my remote to change the sound on the TV.
I located another remote via a friend and solved the problem.
Thanks anyway guys:)
Jul 09, 2009 | Philips Televison & Video
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
No control over magnavox tv
you need an original remote to fix that problem
Oct 10, 2008 | Televison & Video
SET TV WITHOUT REMOTE
Press and hold both volume buttons at the same time to enter the menu then use the volume keys to select CH SET
Sep 13, 2007 | Broksonic CTGV-5463TCT TV
Pioneer HTD-510 System Logo
Top Pioneer Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Jax Planet
Jax Planet
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
