Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Kdl37m4000 sony tv timer / pic off blinks will not turn on? and i have no remote?
Posted by renee on
  • renee Aug 18, 2012
    i have no remote and the tv wont even turn on
    ok found the remote just have to see if it works
kelvin
    New Friend:
My sony bravia kdl-37m4000 have timer pc/off blinking red.
Posted on Aug 10, 2013
3 Related Answers
Anonymous
SOURCE: my sony bravia 32
Unplugging compleatly should reset any kind of timer settings. I've had a look through the manual here though and there is NO mention of this atall.. Very strange..
If you solve it, let me know!
Posted on Dec 16, 2009
aviandragon
  • 125 Answers
SOURCE: I have a sony braiva kdl37m4000 it has a code
Your error means your set has something wrong with its power. If you're into electronics you may find that your power supply just has some bad caps (though this is unusual for Sony), but if you're not into soldering then you'd better find a local repair shop. Good luck.
Posted on May 05, 2011
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: I have a Sony Bravia KDL-46V4100, when I turned on
How many times red standby light is blinking after 3 seconds long pause on your tv front?
This info will help me to diagnose the problem in tv.
Thanks.
Posted on Jun 18, 2011
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
Sony tv will not turn on stand by timer light blinking
Try as suggested to count the blinks to see if it is an error code or not. blinks will be in a sequence with a pause and blink the same number of times over and over.
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
I have a sony braiva kdl37m4000 it has a code flashing 2 blinks pause then 2 blinks what is the issue?
May 05, 2011 | Sony Televison & Video
No picture but sound
how many times your ligth blinks?
5
if so you need to check your g2 voltage
let me know so i can get you more details
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by timer
stand by timer is blinking green tv will not come on
Aug 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv, no pic or sound, lcd blinks
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Dec 31, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
746 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
