Paper moves as it should. Just no tracings. All else seems fine. occasionally very faint lines can be seen.
Ekg machines print on thermal paper, This means that the impression is made by the print head heating the paper. If the print head is not making contact with the paper, you will get a faint tracing or no tracing at all. This needs to be adjust by a technician. Contec is located in China and we are a dealer. If you need their info or want us to look at it for you (for free) simply give us a call
Discount Cardiology
805-484-9985
With over 3 decades servicing medical equipment, I would summarize the 3 most likely issues:
1) the (chemically treated) Thermal Paper is not fully in proper contact with the Thermal Print Array (print-head) for proper heat transfer to 'dicolor' (blacken) the 'waveforms' being written onto the moving graf-paper from the Roll of EKG paper. -try gently pressing the paper's lid while a faint 'trace' is in motion during middle of print-out process; and see if it dramatically darkens a faint trace. Alternatively (thereafter) - very gently pull lightly on the paper while it is in motion, but not in the way it would tear off, to see if contact is so light that paper slips..
these symptoms are more likely in older units with lots of 'miles' on them.
2) cheap or bad paper, poor quality chemical surface or excess heat during storage or transport.. try swinging a fast line with a metal-tipped un-open ballpoint pen across the red graffed side of the paper while it is directly on a hard smooth surface (like a formica counter-top or a clip-board)..
3) if these simple checks fail to identify the trouble, and the thermal Print-head is not occluded (e.g. from a build-up off of cheap paper etc.), which being relatively new should not be the case; then probably and most likely - the orint-head resistance or energy/heat calibration is incorrect or was set improperly (or not at all) from the factory (or it's circuit-board is failing)
. . . and if the manufacturer of inexpensive equipment does not even have a cheap .PDF user's guide and service manual on their web page; then getting it Calibrated again orobablywont be cheap or simple - -and you may well consider sending it back - - If they give you even 2mm of trouble to replace it with a new and properly Calibrated unit, you may wish to consider insisting on getting your money back and changing to a company that takes the manufacturing of diagnostic medical equipment more seriously than an X-box or a Nintendo - and I don't impune those companies' GMP or Quality Control and testing procedures.
Manufacturers do often show you what to expect of them. Not giving youthe info (nor, as has been indicated, making it (easily) available on their web site may or may not be telling you a lot.
Good luck, and remember the old saying . . . "when all else fails, read the instructions" . . . and also, "why wait till all else fails". For decades, organizations like JACHO and the FDA have required manufactures of medical devices to properly equip qualified medical personell with manuals and parts - these days it often seems like people just wait for the law suits before doing what's right ...
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
SOURCE: EKG supprt
Recently, the USA government approved the first pocket-sized EKG machine, so small that it promises easier, faster heart measurements in ambulances, the emergency room - even a possible heart attack victim's bedroom. This devices are already avaliable on special stores and on the internet and usually reffered to as "handheld EKG machine". The most common one is called "ReadMyHeart".
SOURCE: Omron Portable Ecg Ekg accuracy problem
Hello Josh. You will need a EKG simulator. I suggest you contact your local community (junior) college electronics class or a local Bio Medical services in your local hospital. When locating one kindly walk in and ask very nicely with the portable in hand if you my perform a operational test for you on benefit.
SOURCE: ECG PAPER DOES NOT ADVANCE
Hello fbadin1, contact Marquette/GE with model # of unit and order the paper drive assembly. Been there do that. Merry Christmas.
SOURCE: EKG question
The original german spelling is EKG = Elektrokardiogramm, and is used in the medical field as well as ECG - the english abbreviation.
