Tumbler plate fell off so key is usefull
SOURCE: Ignition lock cylinder jammed up
when you have pulled the steering wheel of you'll see three hex screws the on on the right thats silver and just above that one you should see another hex smaller and dark in color that hex screw holds the lock in place.
SOURCE: I lost my key and need to replace the lock cylinder
I guess you should just replace everything. It would be the easiest way to go.
tumbler plate fell off so key is usefullDoes this make sense to you?
I meant to say the key was useless. I am calling Pop a lock Monday for I thing the only option is to drill and the cylinder is harden
I drilles a 1\8th hole at the base of houseing to push release button and was able to remove the key cylinder. T
update: after removing the steering wheel I drilled into cylinder housing and released the springloaded clip to be able to remove the lock cylinder. look at diagram to determine drill hole location.
