Question about Akai LCT3201AD 32 in. LCD Television
I need the reomote code for Akai lct32z4adp and how to program it
Posted by jtconn32 on
1 Related Answer
Kevin Braid
  • 382 Answers
SOURCE: DVD player not working, only used a few times AKAI
Unfortunately they are a real bare to fix. Unless its a jammed disc it is probably a defective transport. If it is under warranty have it repaired otherwise get an external DVD player.
Sorry I don't know of any easy fix for the integrated units.
Cheers
Posted on Jan 06, 2010
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
Jan 23, 2017 | Akai Televison & Video
Need to program remote for akai
Hello
You want to programme your Akai TV with a universal remote control; I assumes, and posts this solution.
Three digit universal remote codes for Akai TV are:
002/ 0030
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Feb 03, 2012 | Televison & Video
DVD player not working, only used a few times AKAI lct32z4adp 32"lcd tv with built-in dvd player
Cheers
Jan 06, 2010 | Akai CFTD2085V 20" TV/VCR/DVD
Need additional remote codes for emerson tv - codes listed on
Hi if you haven't already, try these codes: -
000, 127 or 141
Sep 07, 2009 | Hughes HRMC11 Remote Control
I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
May 25, 2009 | Akai LCT3201TD 32 in. LCD Television
Hi,have 32" lcd hd tv with built in dvd player,model lct32z4adp... no sound when playing dvd.
Locate audio output ic and trace to dvd unit. Look for open circuit. possible dvd audio out chip bad.
Oct 02, 2008 | Akai Televison & Video
Remote code for Akai 37" lcd with Dish Network
Akai support 216-454-0864 .I have the same problem and called the support phone. The answer is this TV came without a code programmed in it.
Aug 17, 2008 | Akai LCT3285TA 32 in. LCD Television
Akai 27 lcd remote control
it would seem the akai remote codes you have are not programed in the remote you should wright to akai and tell them 1000s of people you have chatted to have the same problem is there any way you could send me a replacement please or could you give me the codes and i will program them my self thank you hope you get this email or letter or phone call what have you to lose.
Oct 29, 2007 | Akai LCT2785TA 27 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
