Question about Toymax Magnavox 37MF337B 37 in. LCD TV
Wont turn on and beeping noise from the back of tv
Our TV was plugged in- and it has a beeping noise coming from the back-- it wont turn on and the power button is no longer red/green
Posted by ncredsoxfans on
2 Related Answers
maatmartin7
matt martin
  • 1258 Answers
SOURCE: We have a maxnavox 37 in flat screen HDTV. When
You have a bad capacitor. It will be a 25volt,2200MF, 105 degrees...and it will be bulged! Results will be a AMAZING! Thanks for asking!
Posted on Mar 04, 2010
Anonymous
  • 1622 Answers
SOURCE: Magnavox 47MF437B/37 works fine until
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope it work with the solution
Posted on Jun 12, 2011
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
My hpw1907 monitor says no input and wont display anything. The cpu also makes 1 beeping noise that last 1 second nd doesnt come back
A one second beep from the computer is standard for a proper boot.
Do you have a TV that you can plug your computer into to see if it is posting video? That would be the easiest way to test if it is a computer or monitor thing.
Tv will not turn on and beeps
It's maybe caused by the the defective HORIZONTAL output transistor,,pls try to locate it near the flyback trans.replace one...Dods
My tv wont turn on and its beeping
Unplug the set, press power and hold for 60 seconds, let it sit for 30 minutes and plug the TV back in, try to power on, if no change! the problem is power supply or high voltage issue.
Picture wont come on, makes noise like it is on, but no go
when u plug the set in does it make a whinning noise or a poping noise. this might be a lamp or a color wheel stalled.
9helpful
2answers
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
1helpful
I have a 1995 rca 52 in television that wont come on when the power is applied. the tv will make a beeping noise when plugged in, but wont come on.
the beeping noise is caused by the relay, there is problem in the circuit. check all the major section like the vertical the chroma and in the horizontal section...
2answers
RCA 32 in TV no picture no sound just a beeping noise TV power is on
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
No pic, beeping noise
It seems to be an issue with the power board. The relay may need to be replaced. I would recommend getting it serviced by a professional TV repairman, than try a DIY..
Toymax Magnavox 37MF337B 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
