I need instructions on how to change the 932 ink cartridge. THANK YOU!
Http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put
your fingers on the upper left hand side of the panel (by the logo: HP
OfficeJet 6700 Premium), You should be able to gently pull the panel so
that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
