At first the screen went white after one bar usage so i rebooted it by pulling the battery out and it rebooted its self this kept happening over fer months then the last time i took the battery out to reboot it, it wouldn't turn back on the red light comes on and the bar comes up but it doesn't fill up all the way I've replaced the battery and i still have the same problem I've also tried charging it to come back on and it doesn't I've tried charging it over night to see if that would help and it didn't I've tried defraging my memory card and that still did nothing i can't find anything on the internet about it
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: blackberry flip pearl constantly reboots.
I've had the same problem, particularly after upgrading the OS. I've been able to keep it reboot free for 24 hours after resending the service books from the bberry portal (and I'm even using it unlocked from T-Mobile on AT&T).
SOURCE: Hello im having problems with
It appears the screen has packed up,you need to take it to a repair shop.
