Print out and Scanning is working well. But copier (xerox) is not working. Tell us tips to solve the problem
SOURCE: We have a Xerox M20
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
SOURCE: scanning problem
check the drivers on the samsung website after putting the model no of the printer which you have there.if they are availiable,you can install them from there.
SOURCE: samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
