The disc is not cracked but looks like liquid in the disc. The recording time is 30min on each side. When I insert the disc in the computer, the computer does not read one side of the disc but reads on the other side. Have I lost my data from one side of 30min if I did how can I recover my data and memories from the disc.
SOURCE: unable to finalise
For some reason one of the discs that i have recorded on will not let
me finalise. When i put the disc in it says recording disabled and then
i go to the finalise menu and the finalise selection is unhighlighted.
How can i fix this so i can finalise the disc and use it on my computer?
thanks
SOURCE: Disc Read error
I do have the same problem. It all started when I started using Sony discs that has a label to write on one surface. Don't know how to fix it. It is now almost useless!
Raj
SOURCE: same problem "movie recording disabled"
Scott,
Since this is a new camera, nothing was changed as far as the disc, it should work, has it been switched to "still" for photos, that's the message that comes up when you change it. You shouldn't have to finalize the disc before you shut off the camera, try starting it with another disc then shut it off replace it with your baptism disc and try to preview the video, if it shows you should be able to aad to it or then finalize it.
randy320sgi
SOURCE: I lost the memory stick and bought another one and when I insert read error
you must get a lavender colored sony stick. the black sticks will not work on older sonys. they do make them and only go up to 128 mb usually around 20 dollars.
SOURCE: Sony Handycam DCR-DVD 202E
i am getting a disk access error in sony camcorder..Not able to record any further..pl. help
