Brother Star 110 sewing machine. The stitch selector (lower knob on the right side) turns but does not change to another stitch. It no longer clicks to turn the mechanism but just rotates as if it is not connected inside.
SOURCE: Brother sewing machine will not make continuous stitches
first you should turn off the machine and let in reset it's internal programs. Yes the feed dogs are very important. start your machine again...set the feed dogs...unthread and rethread teh machine from start to finish to include taking out the bobbin and replacing it. then make sure you bobbin winding in completely in Un using mode...
SOURCE: Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
SOURCE: Hi i'm after a manual for the brother star 110
Had the same problem - found the manual under different country from their website:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000287/star110130eom01enes.pdf
SOURCE: my brother sewing machine, My
check needle to see if it's damaged-roll on flat surface to see if it roll correctly
adjust top & bottom tension according to operation manual
SOURCE: need an instruction book for a brother star 300
Manuals are usually avalible on the Brother site.
I couldn't see this manual listed but you can contact them to ask if another manual would be suitable. Perhaps they can send you a copy as a PDF file via email?
http://www.brother-usa.com/manuals/default.aspx?PGID=3
