Power Acoustik PTID-8300NR Car Video Player Logo
A
Anonymous Posted on Aug 17, 2012
Owners manual power acoustic ptid-8300nr - Power Acoustik PTID-8300NR Car Video Player
1 Related Answer
Anonymous
  • Posted on May 05, 2009
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
My power acoustik ptid-6250 will not cut on anymore. I was listening to it and it started going in out. Then all of sudden it just went out and won't come back on. How do I fix it ?
Going in and out sounds like the antenna cable got loose, but the not turning on sounds like the fuse blew. Worth checking those 2 things out first and foremost.
Do you still have your owner's manual? If not:
http://www.poweracoustik.com/pa2012/manuals/PTID-6250.pdf
I have a Soundstream VIR 8300NR and i don't see a bluetooth icon. Also every time I open up Navi it says NO SIGNAL. Why is that?
the navi requires an antenna similar to a siriusXM antenna. is that connected. the bluetooth issue sounds like the OS.
No sound
you could have blown the speaker output or there is a menu to turn speakers on
How do I add my own pictures for screen savers
Its easy Open the picture and then go to options then select send and send to screen saver your picture.
It doesn't turn off with the car I have to disconnect it
Make sure the red wire is going to a voltage source that turns off when the key is off.
Need a code to by pass parking brake feature
usually not a code. it is unlawful to drive without the parking brake feature hooked up.... but the way to do it is remove the wire from the parking brake and ground it. it will then think the parking brake is on
2helpful
Help i need a wire harness for power Acoustic dvd player
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
