A Wave Broadband remote controls all functions and the Sony remote controls all functions; I have tried the menu to max the volume; a week ago the audio volume could be adjust to max; something happened and now audio volume will not increase past medium ??
SOURCE: sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
SOURCE: Remote control for the TV
It can be the IR recveiver module is bad, you will need the scope to look at the signal output of the IR receiver board, you can try replacing the IR receiver module.
try WWW.SHOPJIMMY.COM
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: unable to turn sound on, picture is fine. volume numbers increases but still no audio
check menu make sure ,,internal speakers are on,,check rca jacks
SOURCE: My Sony Bravia remote control is slowly loosing it's functions.
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
SOURCE: Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
The Wave Broadband Remote has separate buttons; AUX - DVD - AUD - TV - CBL
I pressed CBL and increased volume control button to the desired volume
This took care of my dumb volume question Thanx George P
