NTL VS1500 Cordless Phone Logo
Posted on Aug 17, 2012
NTL d5100 cordless phone: handset 2 can't deliver dialling tone.
I've got a d5100 system which has worked fine for 5 years. And still works ok on the main handset. But suddenly the slave handset won't work. Every time I try to use it, instead of a dialling tone, I get the engaged tone. I've tried de-registering and re-registering the slave handset, but no change. Anyone else with this problem? Even better, anyone else knows the solution?
5 Related Answers
Anonymous
  • Posted on Dec 18, 2008
SOURCE: ntl d5100 digital answering phone system with 4 phones
I HAD THE SAME PROBLEM BUT HAVE FOUND MY INSTRUCTIONS I HAVE A D5903SE WITH 3 ADD HANDSETS YOU CAN E.MAIL ME ON [email protected] OR I HAVE A N.T.L HELPLINE NUMBER 08702413201 LET ME KNOW IF THIS HELPS WENDI
Anonymous
  • 15 Answers
  • Posted on Mar 01, 2009
SOURCE: No dialling tone - just a beeping sound
It sounds like the handset is not 'registered' to the base station/cradle. Solution may be in the user handbook, which you should be able to download at :
www.cordless-phones.uk.com
Anonymous
  • 15 Answers
SOURCE: NTL VS1003 Cordless Phone Problem
You should be able to download a copy of the manual at :
Hope you find the solution there!
Anonymous
  • Posted on Apr 27, 2009
SOURCE: ntld1101 - setting up touch tone dialling
how do i set up touch dial on my cordless phone
saailer
David Burbee
  • 1871 Answers
  • Posted on Dec 06, 2009
SOURCE: i have got an ntl vs2000 cordless phone but no
Go to the following link and download manual for free:
www.cordless-phones.uk.com/userguide/vs2000.pdf
FixYa [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Testimonial: "thanks so much, this is perfect! i can use my phone now!"
Phone displaying 'Out of Range', no dialling tone
This could be due to the fact that one of your phones is off the hook or unplugged. Check and make sure that all devices are operational and charged.. Don't forget to check the phone line itseft.
Cheers
1helpful
The DECT telephone is linked to our mainline phone - however it does not pick up the dialling tone or the ring tone. The battery is okay, the signal is good, but you cannot speak on the phone. ...
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Ntld1101 - setting up touch tone dialling
1helpful
Ntl d5100 digital answering phone system with 4 phones
Philips dect 521/525 - 3 year old phone - No dialling tone on one handset
I had the same problem and my hubby managed to reset the phone by simply unplugging it from the electical network. Just wait for few minutes (the date goes back to 1 Jan 2005), then plug it again and try to dial a number. It should work.
2helpful
8answers
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
2answers
Dialling Tone
HELLO . AM JAMAL FROM SYRIA , I VE THE SAME PROBLEM WITH THREE PREVIOUSLY USED XALIO 300 WHICH I BOUGHT FROM SOME BLACK MARKET. I SUGGEST U TO INSERT THE CODE ACCORDING TO UR COUNTRY , FOR EXAMPLE :
PRESS FIRST " R " BUTTON THEN 99 THEN " RC " CODE WRITTEN UNDER BASE UNIT THEN " R " OR " PAGING " AT THE LOW RIGHT CORNER OF HANDSET .
2answers
Lost phone manual for my ntl d5100
manuals for the ntl phone can be got from here NTL - Original
riz.
Top NTL Lands Phones Experts
k24674
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
