In Control Panel Google Chrome is still there in Program Files it is not there.
SOURCE: uninstalled google chrome and now yahoo messenger icons dont work
I can solve your problem, just follo these steps:
Your problem is solved.
If you still unable to do it,I'll help you in detailed.
SOURCE: i didn't like google chrome
I've never used Google Chrome but believe if you uninstall Yahoo Messenger. Then re-download and reinstall it(Yahoo Messenger) that it should remedy your problem since Google Chrome is now removed.
SOURCE: Google Chrome removal
right click on any internet shortcut icon -> select properties and to the right of where it says Opens with: click "Change"
Now you'll be given a list of recommended applications
If you were using firefox it will probably be right there just click it then click "ok"
if the application you used before isn't there click "Browse"
If you want to use Internet Explorer just go to: My Computer -> C:\
-> Program Files then find the folder called Internet explorer, inside you'll find iexplore click it then click open
let me know if that worked ok for you
SOURCE: google chrome will not load
check ur proxy settings, run registry cleaner reg in out it may solve the issue
SOURCE: we downloaded chrome in order to access google
You can access google earth from any browser.
If you are having problems with your shortcuts, you may have the security centre virus.
Try a full scan with malwarebytes.
Try a system restore if you do not have a virus infection.
programs / accessories / system tools / system restore.
Or access system restore from F8 menu on boot up
