Question about Brother XL-5130 Mechanical Sewing Machine
How to wind bobbin - Brother XL-5130 Mechanical Sewing Machine
Posted by aimbsolution on
sylviaivie
  • Brother Master
  • 1,564 Answers
Please see PDF page 26 in your manual. I've included the PDF for your convenience.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Posted on Aug 17, 2012
Bobbin is not feeding properly- didn't wind on evenly.
It is important that the bobbin be wound smoothly for the machine to operate properly. First, check that you are threading the machine correctly to wind the bobbin. There is a tensioner for the bobbin winder that helps wind the bobbin smoothly so incorrect threading will cause issues. Also, try to wind your bobbin slower. There is no advantage to winding the bobbin on high speed.
If you continue to have bobbin winding issues, there is a standalone bobbin winder (SideWinder) avlb at JoAnn's or even Amazon for ~$30,. They are electric or battery operated. Be sure to verify your machine bobbins will work on the SideWinder before purchasing as some bobbins are not compatible. The bobbin winder is a handy gadget since multiple bobbins can be wound quickly, plus bobbins can be wound without having to unthread the machine, not to mention reducing the wear and tear on your sewing machine.
Nov 10, 2017 | Sewing Machines
How to spool thread onto the bobbin
That is called winding the bobbin. Depends on the make & model of your machine. Search for:
Make Model wind bobbin
How to Wind Bobbin Sewing Machine
How to Wind Bobbin
Jul 06, 2017 | Sewing Machines
Singer 9217 thread winds under bobbin instead of on bobbin
Make sure the bobbin is seated all the way on the winding pin. There may be an adjustment for it--a technician can probably fix it for you. However, you can also try lifting the thread with a pencil tip just before it winds onto the bobbin. Some of my machines wind the thread unevenly (more on the bottom than the top of the bobbin) and I balance it out by lifting it when winding.
Oct 07, 2016 | Singer Sewing Machine 9217
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
What's your problem?
if the bobbin thread is winding around the bobbin winder spindle then
the bobbin is not sitting correctly on the bobbin winder spindle,,
the bobbin (metal or plastic) should lock in on the bobbin winder spindle
& the the thread should be around the bobbin tension guide
Apr 04, 2012 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
Bobbin won't wind correctly!!
Iam very picky about my bobbins!
make sure you are threading the machine for the bobbin correctly, In my opinion I don't think any machine really winds well.
What I do is hold the thread about an 1" away from the bobbin. start to wind and I guide the thread slowly up and down the bobbin so that it winds even
Aug 28, 2009 | White Sewing 2200 Multi-Tasker
Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Nov 12, 2008 | Sewing Machines
Brother XL-5130 Mechanical Sewing Machine Logo
32 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
