Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
You will get its manual also with it, describes all the proceedings and codes for different set to which it can be used. OK.
