Question about Sharp Office Equipment & Supplies
Sharp wont let me print 6 3/4 envelopes. how to do it?
Sharp MX-2610 N
  • 2 more comments
  • kim meece Aug 20, 2012
    The error code says tray is empty, but I have placed envelopes in there...The options in size on the printer are COM-10, Monarch,DL, and C5.
kim meece
The error code says tray is empty, but envelopes are in there...The options in size on the printer are COM-10, Monarch,DL, and C5, none of which work for the size of envelopes I am using. :(
Posted on Aug 20, 2012
5 Related Answers
Anonymous
SOURCE: Jobs going to Sharp MX-C311, but printer not
Worked with Sharp Support- client was using accounting and passcode was not set
Posted on Jan 21, 2010
Anonymous
  • 238 Answers
SOURCE: Sharp MX 450 does not
take to service centre
Posted on Aug 12, 2010
Anonymous
  • 8 Answers
SOURCE: How to setup SHARP MX
Buy a wireless print server. Which ever company you buy from will have a help line and guide you through set-up. They are priced $60 to $100
Posted on Aug 17, 2010
unkl foddy
  • 120 Answers
SOURCE: How do i print a big envelope in a Sharp MX 3501N
Select the heaviest paper setting available and only use the right-side manual feed tray.
Posted on Feb 24, 2011
unkl foddy
  • 120 Answers
SOURCE: what envelopes will work on
Most envelopes should work as long as you have:
1) fed them from the right side manual feed tray face down with the short side to the copier.
2) selected ENVELOPE as your paper type to run slower and lower your fuser heat.
The copier is designed for envelopes that have the flap down and the regular wettable adhesive. If you have gummed adhesive with a waxy peel strip that you remove before closing, the copier may not be designed to handle this. It may also help to put the front and rear pressure tabs on the fuser in the UP position.
Sharp MX-3501N will not accept envelopes
here is a walkthrough for printing on envelopes. basically you have to set the machine for envelopes then set your print job for envelopes.
How To Print on Envelopes or Labels on Sharp Printer
Copier Collin Houston TX Copier and Imaging Expert
Jun 30, 2014 | Sharp MX-3501N All-In-One Printer
How to print on transparency film on sharp ms 311ON
Firstly, make sure that you have copier safe transparencies.
Then follow the instructions below, except choose transparency instead of envelopes/labels. and make sure you choose the correct type from the print driver as well. They must match for it to pull the paper in.
Dec 06, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
Misfeed and printing prob
You need to put those levers on the fuser down so there is enough pressure to fuse the toner properly to the paper. Only put those levers up if your doing envelopes or heavy paper.
Dec 14, 2011 | Sharp MX-2300N Color Copier
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
How do I load an envelope into a Sharp MX-M350 copier?
In the bypass tray on the left side of the machine, face down envelope flap opening toward the rear of the machine.
Sep 05, 2011 | Sharp MX-M350 All-In-One Printer
How do i print a big envelope in a Sharp MX 3501N printer? Which option should i select?
Jan 17, 2011 | Sharp MX-3501N All-In-One Printer
How do you print an envelope to copier from computer
Install the print driver, from the app you are printing from select your copier and then Properties, under the Paper tab you can select your paper type and tray. Only use the right side manual feed tray for envelopes. You may also need to set paper type ENVELOPE COM-10 in the copier. Extend the manual feed tray fully and set the guides or the copier will not read the correct size.
Dec 02, 2010 | Sharp MX-3501N All-In-One Printer
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
