Computer frequently does not recognize my Nikon Coolpix S3300. It will connect to it, but the uploader will not come up. When I go to the camera through My Computer, it tells me that the computer cannot detect the camera and to make sure that it is on and properly connected. This happens to multiple computers with this camera -- sometimes it will connect, sometimes not. I have reconnected multiple times. What can I do to make it connect so I can download pictures?
I just experienced this problem and went round in circles for a few hours before stumbling on the solution. My camera, a Sony Cybershot, has 4 USB Connect modes in the Setup menu: PictBridge, PTP, Mass Storage, and Auto. The only mode that would work to bring up the Camera Wizard screen on an XP computer was PTP. Once I changed the setting from Auto to PTP, the camera was recognized and able to connect to the computer. Somehow this setting had got changed to Auto or Mass Storage and that evidently causes a problem such that XP does not recognize the camera.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
SOURCE: When I plug the Nikon
i try to upload photos from my nikon coolpix p50 to 'my pictures' by using my usb cord. it always used to work but not now. something pops up that says "please make sure the device is turned on and properly connected to the computer." i used the the same usb cord as before when it worked.
SOURCE: cant upload my pictures from my camera (Nikon
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer, available along with the current versions of all (free) Nikon software, from http://support.nikontech.com/app/answers/detail/a_id/61
SOURCE: how can i upload pictures from my nikon coolpix
Hi Steel,
Open Windows Explorer and click on My Computer so it displays the drives.
When you attach your camera to the USB cable, the computer should interpret it as another hard drive being attached.
If it doesn't pop up immediately, click on View, then click refresh. It should show up then.
Best regards,
Mike
SOURCE: i have a nikon l18 coolpix and when i plug the usb
Buy an inexpensive card reader to download your pictures to a folder you create on your desktop.
