SOURCE: I need a power supply
try buying a external case and putting the hard drive in the new case.
SOURCE: fantom drive is not being detected. Shows a solid
Since you've already tried different cables and computers, that eliminates a lot of things. Are there any configuration switches?
Possibly a cable or connector has come loose within the unit, particularly the edge connector that connects to the drive itself. If the unit is under warranty, try that first, espcially if you don't have important files that could be lost on the drive if you had to send it in for repair or replacement.
If you open it up, re-seat the connectors --- push them firmly into the drive PC board. If possible, remove each and put it firmly back into place. If that doesn't fix it, something is probably burned out and it is probably not something one can handle without access to factory replacement parts.
SOURCE: My Fantom 500gb hard drive locks up soon after I plug it in.
maybe its driver compatibility issue
SOURCE: I can not locate a driver for my Fantom Titanium
Your device should not need drivers Fte Fantom/Titanium drives are fully supported by both Windows and Mac OS's.
Try replacing the cable or using a different USB port.
Sorry I cannot be of more help, The drive itself may be damaged, You can test this by physically removing the drive itself from the case and installing it internally to your system....If the drive functions properly, then the problem is within the board inside the casing.
Ed
SOURCE: I have a clicking 500GB
Hello, if you mean clicking as in making a clicking sound then I am sorry. Your drive may have suffered an impact that caused damage to the boot sector and master boot record. This prevents it from initializing in my computer. You can try to recover your data using recovery software or send it to a recovery specialist.
I hope this helps, thanks for using FixYa.
