How do you prevent or stop ghosting
SOURCE: Help my A045 Gestetner will not load paper after
If you are changing a paper roll, make sure you can advance the paper through the "throat" using the green knob and then manually trim it. If you are loading paper in the cassette tray, make sure you adjust the green sizing guides to match the paper dimension (8.5x11", 11x17), etc.
SOURCE: Our Gestetner A045, with RW-240WP is giving an error.
make the reader option is enabled in the server application
there should be 4 applications running
SOURCE: looking for some one to work on a gestetner a045
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
