Question about Akai LCT3201AD 32 in. LCD Television
24v supply absent in mlt 688 power supply - Akai LCT3201AD 32 in. LCD Television
1 Related Answer
Anonymous
  • 21 Answers
SOURCE: I need Power Supply MLT 386x - Do you have any? How much?
Hi
Please go to ebay and buy your power supply board:
AKAI LCT3701AD POWER SUPPLY BOARD MLT386X
Posted on Dec 30, 2008
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
There are universal power supply units available that come with a variety of interchangeable ends and switchable polarity, current and voltages. However, if one of these will fit your particular needs I have no idea or indeed if they are available in your country. Try eBay or Amazon. I hope that is of some help.
Dec 09, 2015 | Computers & Internet
What would cause no 24v power from power supply?
Hi aqhnc,
You need to change the whole power supply unit. Your transformer inside it might broken and need to fix.
I hope my solution may help you.
Thanks for using Fixya...;-)
May 06, 2014 | Polaroid FLM-2601 Television
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
Error code 0803 in ir3300 canon copier
The 24V output from the composite main power supply PCB is absent for 1 sec or more. Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB or DC controller PCB is faulty.
Sep 06, 2011 | Canon Office Equipment & Supplies
5v present on stb voltage but no 12v & 24v & 5v of system on power supply MLT 070a PLS HELP
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 31, 2011 | Polaroid FLM-3734B 37 in. LCD HDTV
Samsung SCX-4826FN/XAA toner exhausted
You need to replace the toner cartridge with the following part number MLT-D209L or MLT-D209S or MLT-D2092L.
Take these numbers to your local cartridge shop and they will be able to supply them.
Regards GM
May 27, 2011 | Samsung SCX-4828FN All-In-One Laser...
Error code E000803-000
that mean low power or The 24V output from the composite main power supply PCB is absent for 1 sec or more.
Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
PCB (J300)?
Feb 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
Akai LCT3201AD 32 in. LCD Television Logo
53 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
