Some channels work and others show scrambled
SOURCE: LG LCD 37
the main total assy is at fault. unplug the tv for 5mins and plug it back in. if it does not clear itself it needs factory service
have you looked to see if this set functions via the audio/video jacks on the rear? Set might have a tuner problem which could be bypassed by routing signal into audio/video jacks set should have.
SOURCE: lg-32LS3400 scrambled
re check the connection from the component input and tuner. then at the same time the system that you have using like NTSC or PAL, SECAM select the appropriate in your location.if still the same problem contact the supplier sine it was covered by warranty they checked the unit for free.
