Question about Kenmore 15218 Mechanical Sewing Machine
What year model is the kenmore 385.15212/15218 sewing machine
5 Related Answers
Anonymous
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
Anonymous
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
Anonymous
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
Anonymous
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
Who made the Kenmore Model Number 117-812 sewing machine and what year was it masde?
The 117 prefix indicates the machine was a White sewing machine made by Gritzner Kaiser for the Kenmore line. According to this PDF, http://www.searsarchives.com/history/files/sewing_id.pdf , the 812 was manufactured in 1948.
I hope this helps.
Jul 16, 2017 | Kenmore Sewing Machines
Manual for kenmore 38516221301 sewing machine
Sears carries manuals for most of their machines.
Jun 22, 2017 | Kenmore Sewing Machines
It's model no#158.10401.It just needs some care but would like a manual
If you scroll down the page, you will find a manual at this web site:
http://www.kenmoresewingmanuals.com/kenmore_158_manuals/kenmore_158_manuals.htm
Or, you might want to contact this company. They say that they have a lot of sewing machine manuals available:
http://www.sewingpartsonline.com/kenmore-158-10401-sewing-machine-parts.aspx
Here is some information about your Kenmore sewing machine model. It's probably a very nice basic machine and if properly maintained will last many more years.
https://stitchnerd.wordpress.com/2011/06/16/sears-kenmore-158-10401-model-1040-sewing-machine-a-review/
Jun 01, 2015 | Sewing Machines
Hi i want to buy a sewing machine wich one is best. kenmore or brothers sewing machine
I would prefer Kenmore, enmore makes perhaps the largest selection of mechanical machines. The very cheapest Kenmore sewing machines, like the Kenmore Mini (*est. $100) and Kenmore 15208 (*est. $120), stick with a four-step buttonhole, and have just six and eight stitches, respectively. The Kenmore 15212 (*est. $150) and Kenmore 15218 (*est. $170) both have a one-step buttonhole. The cheaper Kenmore 15212 has 12 stitches. The slightly more expensive model has 18 stitches, including a smocking stitch, overcast and elastic stretch stitch in addition to the basics. Both Kenmore sewing machines are good, basic models, say reviews. Both have just a 90-day warranty, however. Bear in mind that Kenmore sewing machines are made by different Asian companies each year, resulting in varying degrees of quality; this also explains the low prices. Some users report difficulty with tension and light fabrics.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Kenmore 19365 Computerized Sewing Machine
Missing manual for Kenmore Jaguar Quick System sewing machine, model # 158.1070180
RE: Kenmore Jaguar Quick System sewing machine, model # 158.1070180
I have this machine and the manual. I even still have the receipt from when I bought it in April 1990. It just stopped working this year. I might hold on to it and get it repaired one day. Handy little machine, I took it everywhere with me. Is there someplace I could send you a scanned copy if you're still looking for it?
Tina
Apr 17, 2009 | Kenmore Sewing Machines
I need a bobbin cover plate for a kenmore sewing machine, model 385. 1884180. It is about 25 years old.
I too am looking for the Slide Plate for a Kenmore sewing machine Model 3851884180. Did either of you have any luck?
Jan 18, 2009 | Sewing Machines
Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Aug 15, 2008 | Sewing Machines
Kenmore 15218 Mechanical Sewing Machine Logo
521 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
