Question about Power Acoustik PTID-5800 Car Video Player
Were can i get replacement parts for my power acoustik ptid-5800
5 Related Answers
hogan doan
hogan doan
  • 227 Answers
SOURCE: Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
Posted on Mar 07, 2008
Anonymous
  • 7 Answers
SOURCE: Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Posted on Aug 07, 2008
Anonymous
SOURCE: help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Posted on May 05, 2009
Anonymous
SOURCE: how to bypass e-brake to veiw movies all the time
HOOK IT TO THE GROUND WIRE (BLACK)
Posted on Nov 20, 2009
Anonymous
SOURCE: i have a power acoustik ptid-5850n, It will not play any cd, dvd, mp3, ect., it will not play anything except sd card, usb, and radio???
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
Posted on Jan 23, 2010
What are the features?
POWER ACOUSTIK PTID-3265S CD/MP3/USB/DVD 3.2" TV STEREO SCREEN & 6.5" SPEAKERS
Mar 08, 2013 | Power Acoustik PTID-3265S
Bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
Feb 03, 2010 | Power Acoustik PTID-7250N Car DVD Player
Where can i get a replacement faceplate?
The Manufacturer Power Acoustik has them, you need to call and check that they aren't back ordered or out of stock.
Aug 23, 2009 | Power Acoustik PTID-5850NR Car Video...
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
RADIO
over heated it man thse radios very poor heat protection off brands not great for sterios alll day no ventlation main amp no good i would just get new ken wood calrion ect ok
Oct 08, 2008 | Power Acoustik PTID-5800 Car Video Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Mar 03, 2008 | Power Acoustik PTID-4005 Car Video Player
Power Acoustik PTID-5800 Car Video Player Logo
97 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
