Crown XLS 602 2-Channel Amplifier Logo
bryan Posted on Aug 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble shooting crown xls ampilifier602
One channel has stopped working how can i fix it?
Anonymous
Level 3:
  • Master 5,807 Answers
  • Posted on Dec 03, 2012
Anonymous
Master
Level 3:
Answers
5807
Questions
0
Helped
271965
Points
13914
There are two similar circuits , use the good channel as a guide in
troubleshooting.
4 Related Answers
Anonymous
  • 55 Answers
  • Posted on Oct 09, 2010
SOURCE: I have a Crown XLS 1000 running in stereo highpass
Make sure you are getting a signal into channel 2, A cable swap will tell you this.
Anonymous
  • 3 Answers
  • Posted on Feb 24, 2010
SOURCE: left channel not operating on crown xls 602
Every time i have this prob i've blown that channel. In my case i,ve had dodgy connections to my speakers and if it is operating with high voltage rails they don't take much to blow.
Take off cover and you will no doubt find fuses somewhere blown. If it has come from speakers you prob done the amp but if not you might be lucky and just have to replace a single fuse or so.Good luck,Paul
Anonymous
  • 308 Answers
  • Posted on Mar 04, 2010
SOURCE: There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
Dexta K
  • 8 Answers
  • Posted on May 21, 2012
SOURCE: Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
Crown XLS DriveCore 2 Series XLS2502 Power Amplifier. How do you fix a blown channel on a Crown 2502 drive core.
Question edited for a lot more clarity.
Question moved from Cars and Trucks Category.
Take it in for professional repair unless you have the test equipment.
https://www.google.com/search?q=Crown+XLS+2502+drive+core+repairs
Aloha
Crown XLS 602 Amplifier - Channels sound different
you are riight there exist several amps like that they having different frequency on each side i supose its not properly made like that or better they wanted a pasty sound on one side and a thin on the other many times it happened to me - in older days specially lots of european amps the solution is a equalizer on the front and equilze it smoth how u want it
I have a Crown XLS 802 amp that works fine but the fans do not work. They, however, are not frozen. Any help is appreciated. Jim
It is capable of detecting cooling fan failure so I would presume it hasn't decided to engage the fans yet.
How do you "bridge" a d.j. 2 channel power amp? it
Very carefully... SInce the outputs are not specified as isolated, your speakers would be connected across the hots and the returns would be jumpered.
Then for the two inputs you would drive them balanced into the XLR connectors from a single balanced source and reverse pins 2 and 3 in ONE of the connectors of this Wye cable into one of the two inputs on the amp.
The fault light immediately comes on my Crown XLS 602 power amp immediately upon turning it on. It will not go out?
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Mike Cairns
Mike Cairns
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
