Question about Electrolux Dishwashers
E11 code on electrolux dishwasher - Electrolux Dishwashers
Posted by Ann Shilling on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
You are experiencing a drain valve issue - Main Control Board timed out before receiving status of drain valve. Check wiring between Main Control Board and drain valve. If correct, replace drain valve. If error still exist, replace Main Control Board.
Posted on Aug 20, 2012
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
How do you fix e11 code?
Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
Sep 06, 2014 | Electrolux Washing Machines
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
Dishwashers
Hello Paul, thank you for allowing me to assist you!
If you are receiving an error code E11, your dishwasher has detected an issue with the main control board timing out before receiving status of the drain valve. A qualified technician would pinpoint the problem by checking the wiring between both parts. If the wiring isn't the issue, he would need to determine whether the problem rest with the main control and valve. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
Best regards!
Oct 31, 2013 | Electrolux EWDW6505GS Fully Integrated...
My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
E11 indicates a communication error where a technician needs to diagnose the control board.
Jul 23, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Dishwashers Logo
1,061 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Marvin
Marvin
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
