SOURCE: I have a Prospect Pro205. I can't find a manual
Here's the link for the Lexmark Pro200 Series User's Guide: http://bit.ly/aQqy0Y
Here's the link for the Lexmark Pro200 Series Network Guide: http://bit.ly/b9Mzb3
Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
SOURCE: Lexmark prospect pro205 how do I
If you open the panel where you replace the ink cartridges there is a square hole directly behind the control panel. The area gives you enough space to put your hand under the plastic and you will feel what I only describe as a plastic latch, pull it and you should feel the control panel loosen to then be able to close.
Hope this helps...
SOURCE: Our Lexmark Prospect Pro205 has
Your cartridge may need to cleaned. On the printer operator panel, press Setup button -> Maintenance -> Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, your printer probably needs to be updated. The firmware update, available at http://bit.ly/p205fw, will help fix print quality issues.
SOURCE: when i connected the lexmark
This could be because of some blocked printer communications. Make sure to allow these communications in the program rules/permissions for your firewall. These articles should guide you on how to configure your firewall.
- Cannot Print or Scan from the All-In-One Center with Any All-in-One Inkjet Product; Firewalls Prevent Unknown Processes from Functioning
- Communication Failure When Trying to Scan, Print, or Perform a Smart Solution Function; Firewall Possibly Blocking a Process and Preventing Communication
SOURCE: Paper will not feed into
hi,
Lets clean it this way;
- open any documents
- go to file > print ( or ctrl + P)
- When the print window opens click 'properties'
- In the properties window click 'Maintenance'
- 1st do the normal 'cleaning'
- 2nd do the 'deep cleaning'
- do the print Head Alignment'
- do Nozzle check'
- Skip 'Ink cartridge settings' (if the ink level is ok)
- do 'Bottom plate cleaning'
- do 'Roller cleaning'
- click 'OK'
- turn Off and ON printer.
Now insert the load paper and take print. : ) done
Hope this helps.
Please rate if this solution was helpful, thanks!
Lexmark recognizes that some of our inkjet all-in-one customers
may be experiencing issues with their print quality. We take our customer user
experience very seriously, and we strive to ensure that each time a customer
prints using a Lexmark device the page is crisp, clear and up to the highest
standards.
However, if your device is displaying a 'printhead error' on the hardware and/or you are suddenly experiencing a print quality issue, please contact the Lexmark Technical Support Center at 1-800-539-6275 or point your browser to http://bit.ly/lFKDzs for online technical assistance.
