Its working on win xP but its not working on Windows 7. I need driver for windows 7.
This model is discontinued from OEM. So, it will not work on Windows 7. For more information, please visit the following links:
http://support.visioneer.com/products/9320/default.asp
http://support.visioneer.com/KnowledgeBase/Articles/VIS1493%20-%20Updating%20Your%20Scanner%20Driver.asp?ScannerModel=DM3115&bit=32
Hope the above information is helpful.
Thanks & regards,
Scancare
SOURCE: scanner not working
There is not a driver available for Windows 7. One thing you can try is to run the software in windows XP compatibility mode if your version of Windows has it. When you go to run the software disc for the scanner goto my computer and right-click on the icon then click properties. You can then set the compatibility mode to run on XP. Then run the software by double left click on the icon after you have set the compatibilty mode for XP. I cannot guarantee this will work but it is worth a try. If you download the software to the desktop the process is the same.
SOURCE: need drivers for windows xp pro 64
The XP driver is available at:
http://support.visioneer.com/products/8700/downloads.asp
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
SOURCE: Need a driver for Windows 7 please
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
