Question about RCA H125 MP3 Player
77xinst.bat not found
I want to install the driver disc to put player lists but it appears 77xinst.bat not found what can i do? but if you have a better way to put playlists without the driver that work to
Posted by santilink97 on
1 Related Answer
Anonymous
  • 26 Answers
SOURCE: RCA M42 series mp3 player playlist
try creating a new fold inside your music file that all your music shows up in and say call it Myplaylist then drag other songs into there and see if it shows up
Posted on Jan 14, 2009
Sony vista dvd player not working after service pack 2 installed
The first place I'd look for a problem is in Device Manager. To get there click on start button, right click computer, click manage and wait a few seconds for a window to appear. On the left side of the new window click on Device Manager. You'll get a list of conputers components. Beside where it says CD/DVD Rom Drives click on the little triangle to open the disc drive section. If there is an exclaimation mark or some such beside the details for you dvd player its likely a driver issue. The driver probably needs updated. Click on your DVD in the Device manager section to highlight it, then with the cursor over the highlighted info right click. A drop down menu will open, click on update driver software.
Also you need to ensure all window updates have been downloaded and installed. To do this click start button, click all programmes, look along the list of programmes for windows update and follow the onscreen instructions.
Doing both of these will hopefully sort you out. You could also update your driver software through Sonys website. just go to their site, then from there go to support then downloads. Put in the type of dvd player you have, follow onscreen instructions to download the latest driver for your device and install.
If its still not working try typing your question in google. Chances are if its happened to you its happened to someone else and they might just have the info you need.
Good luck........
How do you put songs on it!?
Hi there, plug your mp3 into the computer through the usb cord. A window will appera in less then a minute (a fast computer it will be seconds) a window will appear asking you what you want to do with this'device"..Close that window (x). Click the "start" button on the screen (in one of the screens corners), a menu will drop down, click on "my computer". This will open up a window. In this window you will see numerous "discs" listed (for example, the harddrive is usually disc (c)...)I had a mp3 player that was under disc letter (f) and I've had a mp3 player that was under disc (e), I don't know why, but you need to open any "discs" you have. one by one (skipping disc (c) the harddrive usually). Once you open a disc you are looking for a folder (it could have the name of your mp3 on it, or it could be just some wild numbers, sometimes it's actually marked "music"). Just open any folders till you see the music, pictures or video's you are looking for, then you'll have found the folder to your mp3, now you can copy the song you want (or mp4 jpeg etc) and paste it in this folder and it will appear in your mp3...
Let me know how it went, , if you have anymore questions just ask me and I'll do my best...Don't forget to rate, thank you!
This workes on most all digital cameras, mp3/mp4's and also cellphones...those will be listed as one of the "discs" in the "my computer" window (folder)e73b04a.jpg
1helpful
I need the drivers to download songs on my naxa nx-187 and no they dont have the software on their website
Hello.
Please follow these steps to put music on your Mp3 Player.
  1. Start off by putting a battery in you Naxa mp3 player. This is necessary in order to add music to a Naxa mp3 player. Naxa mp3 Players require one AAA battery and this battery goes into the back of the device.
  2. Plug your Naxa mp3 player into your computer. To do this, take the cap off of the bottom of the player. You will then be able to plug the Naxa mp3 player directly into a USB port on your computer.
  3. Open Windows Media Player and then click the "Sync" tab found at the very top of the program. Once you do, you will notice that the Naxa mp3 player is listed in the top right corner of Windows Media Player.
  4. Double-click the "Library" link on the left side of Windows Media Player. Once you do, several different options will appear underneath "Library."
  5. Click the "Songs" option found below "Library." Once you do, a list of all of the songs in your Windows Media library will appear in the middle of the program.
  6. Browse through all of the songs in your library and right click over any song you want to add to your Naxa mp3 player. After you right click on a song, you will need to select "Add to Sync List." You will then see the song listed in the column on the far right side of Windows Media Player. Continue doing this until you are finished putting music on the Naxa mp3 player.
  7. Click the "Start Sync" button located underneath the list of music you selected in Step 7. The music will then be added to the Naxa mp3 player
Thank You
From eHow.
I have a CanoScan LiDE 70 scanner. It won't speak to my computer. It is plugged in to USB. Message appears saying try switching it on, but I can't find any switch. Icon appears in directory. Tried re...
first check whether u have installed all the usb drivers
then uninstall the scanner software and install it again without connecting your scanner.
there is no switch on it u will have to remove the power connection
restart ur computer when u finish installing the drivers
connect your scanner when u restart ur computer
26helpful
9answers
Samsung YP-U3 driver
REALLY REALLY REALLY REALLY WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! yes yes yes yes!!!!!!!!
I solved the problem after i was really crazy of anger with samsung company, but i found this solution in one forum.Thank you
very much, anonymous Guest!!!!!
Hi All,
I just solved the problem after many attempts!
It works for me, and i hope it works for you too~First install media player 10!
When I plug in my YP-U3 player, the computer says it needs to search for a driver, then i let it search it online. But it normally
won't search the driver on the internet. Then, it will give a prompt to ask if you want to find a solution or search the driver from
the PC. Choose the second option, searching from the PC. Then change the directory to C: (Which is the most crucial part).
After a while, the driver should be found and a warning message will appear. Forget about the warning, choose install the
hardware anyway, player should be recognized by then.
(I have had windows media player 11(10 also works), direct X 9...etc. before installing the driver)
2answers
RCA Lyra H100A
You must be running Windows 98 - see if RCA's website has the driver - you must have that driver or the installation CD - there is no other way (unless you get a computer running Windows XP or higher):
1. Insert the supplied installation CD into the CD-ROM drive first.
2. Read the readme file of the installation CD.
3. Double Click “77xinst”, then Restart Computer.
Method Two:
1. Insert the supplied installation CD into the CD-ROM driver and
connect the unit to your PC via the supplied USB cord.
Note: Do not select the charging battery mode after connecting the
unit to your PC. Please see page 4 for details.
2. If the player is recognized by your PC, the “Add New Hardware
Wizard” is activated, and click “Next”.
Win Virtual Driver
You need to manually install the driver from the installation cd. This is the only sution to the problem.
Thankyou
Problems with my rca mp3 player
looks like you have posted on the wrong forum
1helpful
I need driver for ASUS W5000a (K022462A1)
The drivers for your laptop are here: http://support.asus.com/download/download_item.aspx?product=3&model=W5A&SLanguage=en-us
3answers
RCA H125 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Ekse
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
