Question about Gateway DX4860-UB32P Desktop PC - REFURBISHED
Gateway desktop cop. DX4860 : Start switch on light is not lit steady, it is flickering, the comp. running without any problem.
Start light (comp. on light) is flickering and very annoying.
  • kridevill
    kridevill Sep 29, 2012
    logo light not working
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
This means it is processing, if the light stops, you are in trouble. If it annoys you, cover the light with something....maybe put a cup of coffee infront of it! :)
Posted on Aug 16, 2012
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
Airbag light staying on
You need to connect to vag com or some else computer program to see the error code and when remove prroblem you need to delet the error from car computer memory to get rid of the light.
The most common problems are: blown fuse, bad connection under the seat or something like that! But you can't do nothing without the comp.
Nov 30, 2010 | 2006 Volkswagen Jetta
Monitor dims and flickers. doesnt get hot. the cables and outlet are all fine also. works but the flicker is annoying makes a weird sound on startup. no other refresh rates to choose from.
Dim and flicker problems are a sign of a back-light problem and it could be a faulty inverter board or a CCFL lamp.
For service, parts and DIY info check out LCD parts - Click on this link to their WEB site :-
www.lcdparts.net
Dec 19, 2009 | Acer 22" X223w LCD Monitor
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
2005 uplander,when the van is runing the head lights flicker
If voltage regulator is good, then the dimmer switch is probably bad.
Sep 04, 2009 | 2005 Chevrolet Uplander
Amama Fridge lighting problem
First tighten the bulbs securely. If not loose bulbs you have a loose wire connection.
Aug 14, 2009 | Refrigerators
Nokia 6085 screen flashes off every 5 seconds
I didn't think there were any software updates for the 6085. bring it to your service provider or nokia, or call nokia.
Mar 10, 2009 | Nokia 6085 Cellular Phone
1990 Isuzu Trooper Problem: Flickering daytime running lights
You might have a short in the running light circuit.
Oct 28, 2008 | 1990 Isuzu Trooper
Gateway DX4860-UB32P Desktop PC - REFURBISHED Logo
190 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
