Compatible Toshiba T1810 For E Studio 181, 182, 212, 242 Logo
Posted on Aug 16, 2012
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
bharat kumar sahu
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 19, 2013
bharat kumar sahu
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
628
Points
On out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
My photocopy machine name is Toshiba e studio 2303A. Now showing in the display empty :Toner.
Hello -
Your Toshiba photocopier needs fresh toner.
Check the user manual regarding what toner to purchase and how to add it to the machine.
Best wishes.
Sir i have toshiba e studio 212 machine when i on her empty toner replace toner appear the msg on screen what is the solution
Need to go to an office products company and purchase a toner cartridge. You might be able to have your toner cartridge refilled for half the cost of a new cartridge $80.
Defaut de toner
You have to unable the control of the toner cartridge. Press 0 and 8 keys simultaneus and turn on the machine. Then enter 695 code and press the start key. Change the value from 1 to 0 and press enter.
Toshiba e studio 212 photocopier machine change the toner but massage low toner
The toshiba machine e studio 212 is zerox actual image on in side tray but we are select out side try the image is shifted on output paper.
Toshiba 166 showing toner light after replacing new cartridge
do this first remove the toner from the machine second input the 08 695 0 then close the machine then put the toner back
2answers
2helpful
Why can't I print more than 1 page at a time with my kyocera photocopier C2525E
You are low on toner. The machine should say K, C, Y or M toner is low.
2helpful
Sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Top Compatible Office Equipment & Supplies Experts
ADMIN Eric
ADMIN Eric
Jeena kannanunni
Level 1 Expert
Meer Hadii
Meer Hadii
Are you a Compatible Office Equipment and Supply Expert? Answer questions, earn points and help others
