Red light flashes 4 times
SOURCE: Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
SOURCE: Panasonic TX-32LXD60 won't switch on. Red standby
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Testimonial: "Thanks for your help-at least I know what I should need to pay for to get it repaired now."
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Check this site for more
details. It has more than 1400 posts to
different brands of electronic entertainment and other equipments. All posts referrers with the repair and
fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide
option, can be selected by the sidebar tag at the top left of the display
screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard
option will be the best.
