Question about Sampo Televison & Video
I want to know how to change the digital region for my technika tv
SOURCE: Technika Pro 19" LCD TV/DVD LCD19DVDID-308
Select the DVD and type 9 7 3 5. This brings up a new menu. Select Region 0. OK.
Posted on Oct 25, 2008
SOURCE: technika pro LCD TV/DVD 15.4 HD Digital
if its the model i think it is the lcd15-m3 then go into d.menu (about 6 buttons up from the bottom left) then using the arrows next to the same button go down to the last option which should be setup or settings and press ok.
then go down to instalation (again the last option) and press ok
then down to first time instalation (again last option)
Select yes and press ok, this will bring you up to your original setup page
(menus are the same in most models but almost positive that the model you have is the m3
Posted on Sep 04, 2009
SOURCE: Technika Pro 19" LCD TV/DVD LCD19B-M3
when i watch a dvd on my technika it is green how to i reset the settings so that the colour is normal?
Posted on Oct 15, 2010
I was able to find this at te hp website:
set the language and country/region
Usually, the language and country or region are set when you install the
HP PSC. If you set the country/region or language incorrectly during
installation, use the following procedure.
1 Press Setup.
2 Press 2, then press 4.
This selects Maintenance, and then selects Set Language & Country/
Region.
You are prompted with a list of languages. You can also scroll through the
languages using or .
3 Using the keypad, enter the two-digit number for the desired language.
4 When prompted, press Enter for Yes or Cancel for No.
You are prompted with all the countries/regions for the selected
language. You can also scroll through the countries/regions using or
5 Using the keypad, enter the two-digit number for the desired country/
region.
6 When prompted, press Enter for Yes or Cancel for No.
7 You can confirm the language and country/region by printing a Self-Test
Report, as follows:
a. Press Setup.
b. Press 1, then press 2.
This selects Print Report, and then selects Self-Test Report.
