Question about HP LaserJet 4730 MFP Printer
My printer hp laserjet 4540 mfp has a firmware error
Update the firmware of my printer hp 4540 mfp
5 Related Answers
manojro
Manoj Rout
  • 495 Answers
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Posted on Apr 17, 2009
haivanko
haivanko
  • 37 Answers
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. [email protected]
Posted on Jun 15, 2009
Anonymous
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Posted on Apr 19, 2010
seeker5211
Seeker5211
  • 1089 Answers
SOURCE: HP Laserjet M2727nf Mfp.
Turn off printer. Hold the CANCEL and > buttons, and turn on printer. When you see Permanent Storage Init release the two buttons. When the process completes you will see the ready message. This will reset ALL menu settings. If you screwed up the firmware update, you will have to replace the formatter. The NVRAM reset won't help you!!!
Posted on May 17, 2010
Anonymous
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
Scanner error 12 shows
HP LaserJet M1005 MFP - Scanner Errors 6 and 12 Solution ISSUE: The scan head may not be in the correct starting position.
Updated firmware is available to resolve the issue.
SOLUTION: Upgrade to newer firmware (version20120831 or newer) available on hp.com Support & Drivers.
Select Drivers & Software, enter the product name/number, select operating system and locate the firmware download.
Nov 01, 2014 | Office Equipment & Supplies
Hp laserjet m5035 mfp error 49 ff04
I think you are since the dc controller only controls paper movement and nothing else. A 49 error is a firmware error and has many causes from applications, network and just defective formatter. If the errors occurs with the printer not connected to anything, then the formatter would be the logical issue if the firmware has been updated. Keep in mind having a jet direct card in the slot can cause the error, so the only true way to test is with everything removed with the exception of firmware, memory and power. Also keep in mind that if the 4250/4350 series power is derived from the lvps and not the dc controller. Also with this model the embedded jet direct card is known to occasionally have issues. When you upgrade the firmware for the formatter it also upgrades the firmware on the embedded nic card. Again the only true way to test would be to disable the embedded nic card on powerup.
Read more... HP Support document HP Support Center and HP Printer Support
Jun 27, 2014 | HP LaserJet M5035 MFP Printer
What does it mean when my printer is always writing hp 49 Service Error?
is it new maybe you need to take it in for a service there are things we can't do they are only for techs
Jun 23, 2014 | HP Hewlett Packard TopShot LaserJet Pro...
How to fix error 79 on a hp laserjet pro 400
Try to update your firmware if it is possible. 79 it's a firmware related error. You will find the update file and the procedure on HP webpage at "Drivers and Support" section. If the update won't solve the problem, verify if the formatter board is correctly plugged. Eventually pull it out and push it back firmly.
May 19, 2014 | HP Laserjet Pro 400 Mfp M425dn...
49.38.07 error
It a common HP error. It is a non spesific error. Usuly the printer having problems with a specific job you trying to print . The firmware needs updating, delete that job and turn off and on the printer, make sure IP address ,subnet mask and gateway are correct. Also win servers and DNS settings are all correct.update printer driver. Try printing via host name not IP.
Apr 19, 2014 | HP Laserjet Enterprise M4555 Mfp Laserjet...
My HP LaserJet M1120 MFP will not print if the network cable is plugged in
Mar 15, 2013 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 22 HP laserjet M1213nf MFP
Perform a power reset.
Press the Power button to turn on the printer.
With the printer turned on , disconnect the power cord from the rear of the printer.
Wait at least 30 seconds. Reconnect the power cord to the rear of the printer.
Update the firmware on the printer. I have included the url.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lang=en&lc=en&product=4075457&
May 07, 2012 | HP LaserJet M1120 MFP All-In-One Printer
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Hp cm1312nfi printer problem error ready to download
The error is due to corrupt firmware and you need to reinstall it.
HP CM1312NFI Firmware Download & Instructions
Please visit the above link and Download the firmware.
"The HP Easy Firmware Upgrade utility provides the HP MFP firmware .rfu bundle and a user friendly method to transfer the .rfu file to the MFP all contained in a self-extracting executable for the Windows operating systems"
Please visit the above link and read all the instructions/ details and upgrade the firmware.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the pc during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 09, 2011 | HP LaserJet CM1312 All-In-One Printer
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
HP LaserJet 4730 MFP Printer Logo
56 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
