Como la reseteo con el teclado
SOURCE: Necesito realizar el test de una Laptop Inspiron 8600
My spanish is very poco, but I think you want to start a diagnostics test, and need the combination of keys to start?? That would be the Fn + the Power key. Turn the computer off. Press and HOLD the Fn key, then press and RELEASE the power key. Keep the Fn key down until the screen says that you are starting in the "diagnostics" mode. You will then see prompts to ask if you want to conduct a full diagnostics test or a custom one. If you just want to check one or more parts of the system, choose the custom and select what you want to test. Otherwise a full test will cover all system hardware and will take about an hour.
SOURCE: hola yo tengo una DELL
Remove the CMOS battery and re insert again..you can find CMOS battery located on the motherboard...
SOURCE: resetear bios
Si se ha olvidado la contraseña del BIOS, you' necesidad del ll de entrar en contacto con el soporte técnico en Dell para resolver la contraseña
SOURCE: debo resetear la bios de mi dell inspiron 1525 y no se como
There are 2 ways you can reset your bios.
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting steps, this will not always work but usually will
depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
SOURCE: como le reseteo el bios a mi dell inspiron 1501
Todos los que tiene que hacer es sacar las baterias de tu motherboard y de loptop por ejemplo el de la corriente es por atras y luego la abre por adelante con un desarmador flat pequeno y luego usa uno de estrella con cuidado y saca la bateria chiquita como de reloj y la deja su rato ella misma se resetea...
