Slowly drains battery
SOURCE: 2001 yamaha r6 keeps going dead! Stator,regulator or something?
you need to check for a short if its not that then it could be your altinator or a regulator box
SOURCE: 97 gixxer 750, will not start. Starts fill with
Your charger should be putting out 13.0-14.5 volts to keep the battery charged. Otherwise its running off the stator sometimes and the battery at other times depleating the battery. The voltage regulator could be bad or the stator could be bad. try swapping the volt regulator first and start from there. Also a battery that has been depleted should be sufficiently recharged before using it again.
SOURCE: I replaced my stator on my 1983 650 silver wing interstate
Where did you get the stator?? If not factory... You might want to us a volt meter and measure the resistance. You can find the resistance specs in its honda service manual. Give some more info!!
SOURCE: wire connector between stator & voltage reg/rectifier burnt
your voltage/reg. can be tested in a couple different ways check ground res. check res. then revs. bias on diodes you have ac in dc out it sounds like you may have a diode gone bad allowing ac curent to flow causing the wires to get hot
SOURCE: my battery is not charging when bike is running (gsxr 600 k6 )
When you put a voltmeter across the battery terminals, you should get >13.5V (typically) with the engine running.
If less than this then your charging system is faulty and your battery will not charge.
See this personally authored thread for a diagnostic guide on how to determine whether you have a problem with your stator or Rectifier/Regulator - inlcuding some cold resistance checks you can do on the R/R to determine if it is shorted.
[url]http://www.triumphrat.net/speed-triple-forum/104504-charging-system-diagnostics-rectifier-regulator-upgrade.html[/url]
It was written initially for Triumphs, but applies to ANY 3-phase motorcycle charging system.
