Question about Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio
When i turn on my heater my batery volt dial goes down
When i turn off the blazer it wont turn over until it cools down i have replaced the cable the runs from the battery to the starter before that i had to change a freeze plug that was behind the motor mount and the water was leaking on it i am thinking that the starter is bad but the auto stores are saying that it is something else and it is my only vehicle please help
Dave
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
You might have a voltage regulator problem. If the vehicles voltage drops by more than a volt or two when everything electrical is turned on, that's the most likely problem.
It could also be a bad connection somewhere after the alternator. Or, you have a failin alternator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on May 17, 2016
cliff geiger
    New Friend:
  • 15 Answers
It sounds like your heater moter has a short try unpluging it
Posted on May 24, 2013
1999 Hyundai Lantra runs and then wont start
Either a weak battery or a defective starter. Have you checked your battery voltage when it will not crank? Cleaned your battery terminals?
If you need further help, reach me via phone at https://www.6ya.com/expert/tom_1788908372a4836f
Jan 10, 2014 | Cars & Trucks
Citroen c4 coupe car wont start when engine is hot/starts fine when engine is cool or cold have changed starter motor fuse no change
check electronic spark unit ie coil pack going open circuit when hot
will run but when turned off will stay open circuit untill cools down then closed circuit then will wprk fine
Aug 17, 2012 | 2006 Citroen C4 1.6i
Car wont start till it cools down
Does it have an external starter relay?(Fords are notorious for these going bad).
May 11, 2012 | Ford Escort Cars & Trucks
Cranks runs good but wont crank after running a while then cools down and cranks it does not turn over on speed till it sets a while what could cause this
It sound like you have a bad starter. When it is hot, it is drawing more amps than the battery can supply. You may also need to test the positive cable to the starter from the battery. To do this, you need a multimeter. Check the voltage between the positive and negative cable at the battery and note your readings. Then measure the voltage at the starter between where the cable connects and the case of the starter. Compare the two reading. If you have more than .5 volts difference, then the positive cable has too much resistance and needs replacing. Check for corrosion and make sure the cable is tight as well. I am betting on a starter though.
Good luck. Hope this helps!
Apr 09, 2011 | 1984 Ford Bronco
Ive replaced the battery and starter but it still wont turn over' has power and it starts to click but nothing. 1996 chevy blazer
Check that the battery has at least 13.6 volts and if it does the the starter solenoid may be bad as this occurs frequently these days with rebuilt starters. You may need to return the starter for a replacement but before doing that make sure both your battery cables are clean and tight at both ends.
Apr 01, 2011 | 1996 Chevrolet Blazer
My 96 chevy Blazer wont start but the battery is fully charged wont click or turn over
Your pendix on your starter might be stuck, lay down under blazer and tap on the starter with the handle of a srew driver or a small hamme to see if it frees the pendix. You may have a faulty starter. You can jump the starter with a screw driver to see if it works, but if your not familar with that I don't suggest you try that.
Jul 04, 2009 | Chevrolet Blazer Cars & Trucks
1995 chevy wont start
check the battery termals to see if that are corrosion free and very tight, thats first thing,check the alternator make sure it is putting out, while running remove the pos. battery termal to see if it stays running, if it stops, the alternator is not putting out, hope this helps you, thanks robert b.
Jun 29, 2009 | 1995 Chevrolet Blazer
97 chevy blazer
There are no free full diagrams on the net, you need to charge and test the battery, clean the battery cables and run a voltage drop test as well, replace them if the are badly corroded. Kragen will test the battery for free.
Aug 31, 2008 | 1997 Chevrolet Blazer
Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio Logo
313 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Glenn Smart
Glenn Smart
Vernon Taylor
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
