Logitech R-20 Computer Speakers Logo
Details of adaptor for r20 series speakers model no s 01538
Problem with Logitech R-20 Computer Speakers
2 Related Answers
Anonymous
  • 527 Answers
  • Posted on Mar 18, 2009
SOURCE: Can't find driver for Logitech X-220 speakers
Sir,
click these links for download
Link 1
Link 2
U can also install related any driver. for ex. realtek audio driver so try to install other drivers also.
Thanks Good Luck
Appreciate to rate as "Fixya"
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Mar 22, 2009
SOURCE: speakers
Visit this kink: http://www.new-drivers.com/files/speakers/Logitech/?gclid=CM_a2oOjtpkCFcQtpAod6hp-5Q and download the latest driver for free....sodeep
How to connect Logitech R20 speakers to Toshiba laptop?
It may seem odd but connect them to the headphone jack.
New computer with windows7. r20 speakers logitech . no spund neednew drivers. before was XP drivers
If it is a new computer, then the device-drivers for your computer should have automatically been installed.
Try the speakers on some other computer, to see if the speakers are working at all.
Try some other speakers on your computer, to see if your computer's audio-card is the problem.
1helpful
My logitech r20 speakers problem is when i switch on ,there is no power come out,but then if i push a bit n hold ,there is power come out,.if i release back my hand switch it to normally the button...
The power button on your speakers is broken- possibly from friction due to heavy usage. Unfortunately, there is no way to really fix this that is worth your time- if you still have it under warranty, take it to where you bought it, or give Logitech a call to get them replaced. If you don't, it may be time to search for a new set. While it's more expensive, I would recommend the Logitech Z-313 or Z323 if you want a decent replacement. They will sound better than the R20s, too.
Logittech r20
are your speakers on
is your sound turned up
I can't figure out how to set up either of 2 speakers that I own
not sure if you have looked here for the manual... but you may be able to find it on this site
http://www.logitech.com/index.cfm/409/&cl=ca,en?prodcrid=409
Robert
please take a moment to rate this solution thanks
Logitech r-20 speakers
Hi again andrew63,
There are two possible methods of adjusting the bass and treble output to your Logitech R20 speakers:
1. Hardware - if you feel like experimenting or working with electronic gadgets, you can connect an external preamp with tone control or graphic equalizer between the PC and the input of the speakers/amp; and/or (probably the easiest)
2. Use a software (to listen to your music files/medium) that has a virtual equalizer such the old MusicMatch Jukebox or as an add-on/plug in.
Btw, thanks for asking me to be a Tech Buddy.
Subwoofer not working...!
Hello Lujo
There is a lot problems, arise from this particular hardware, you can RMS your product, Subwofer for a change for other if has warranty, or buy another sub, from any Radio Shack or other store. may be the insider split sound board if bad, or fried.
try any other brand like Sound Blaster Speakers. for 2.1 speakers.
Bass destortion
yes u nee dto get the kilspe 2.1 promeadia speakers way better big bass rocks seprate bass control used set on ebay for 65
Power problem
probably "+" you need to check the polarity of the speakers, there should be something like this near where you plug in the power adapter: http://www.accesscomms.com.au/images/reference/powerplug-positive.jpg the above symbol would mean "+".
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
