Question about Cats
What is silica gel litter? - Cats
Posted by Shelf Hanger on
verid1219
    New Friend:
Silica gel is a porous granular form of sodium silicate, that has the highest absorbency of any litter, and has excellent moisture control and complete odor elimination. I'm using it for a while and I advise you to try it out, you won't regret it.
Posted on Aug 15, 2012
Have a lg g6, getting error that phone wasn't charge because of moisture. My cell hasn`t been in moisture.
Has it been in the cold? If you bring a device inside from the cold, it can condensate inside the unit. This happened to my camera and before i discovered it had grown mold inside the camera, had to be completely disassembled and cleaned. If you bring any electronic thing in from the cold put it in a plastic bag until it acclimates to room temp. If it already has moisture in it you can place it in a bag of silica gel pellets for a day or two and it will extract the moisture. (some types of non-clay kitty litter are pure silica gel)
Feb 22, 2018 | LG Cell Phones
My lgg2Phone fell in water, what can I do to help it dry out?
you can use silica gel. or you can try silica cat litter sand. burry your phone inside of that silica material and it will absorb water.
Apr 11, 2014 | Cameras
I washed my mp3
Hi stantheman10
Chances are its toast, but it is worth a try...sometimes it works
If you ever find that you have to deal with a wet device, don't just abandon it.
Instead, try the following method to repair the water damage:
DO NOT TURN IT ON!
Take it apart as much as you can. Take out the battery, the memory card and whatever else can be easily disassembled. (Just make sure you can put it back together.)
Store the parts in an air-tight container covered with either dry rice, silica gel packets or kitty litter. These will absorb the moisture from your electronics device, leaving it water-free.
If no rice, gel packets or kitty litter are available, try using a vacuum to **** the water out.
DO NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Please take time to rate me.
Oct 09, 2012 | Philips GOGEAR Audio Players & Recorders
Mp3 in water
Hi jorg6..
DO NOT TURN IT ON!
Bud
Oct 04, 2012 | Audio Players & Recorders
Is Silica gel litter safe for kittens?
I would avoid using Silica gel litter in a kittens litter box and wait until they are slightly older. Young kittens are prone to tasting cat litter (simply out of curiosity). Silica crystals can be harmful if ingested and for this reason alone should not be used.
Aug 14, 2012 | Cats
What is crystal litter?
Litter crystals are made from silica gel. It has the highest absorbency of any litter on the market and boasts outstanding moisture control as well as odor elimination over extended periods of time in comparison to other types of litter.
Aug 14, 2012 | Cats
What are the different types of cat litter?
The two most popular types of cat litter are clay and clumping; however there are a few other types that are less popular but still good. Other litter types include biodegradable materials such as plant resources, wood and paper. The newest type of cat litter is called silica. It consists of silica beads/pellets that can absorb your cats ***** without you having to scoop.
Aug 14, 2012 | Cats
Sony Walkman NWZ-B135 MP3 Player water damaged
Hi allison mccl...
DO NOT TURN IT ON!
Sep 26, 2011 | Sony Walkman NWZ-B135 MP3 Player
My ipod went through the wash...any hope it will survive
Hi myoungman56...
DO NOT TURN IT ON!
Free answer...Please take time to rate me.
Aug 21, 2011 | Apple Audio Players & Recorders
My RCA Opal M4202, was washed in the washer last will turn on, is there anything I can do save it?
Hircw51...
DO NOT TURN IT ON!!
If no rice, gel packets or kitty litter are available, try using a vacuum to **** the water out. Do NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Jul 07, 2011 | RCA M4202 MP3 Player
Cats Logo
222 people viewed this question
Top Cats Experts
David Payne - Geek
David Payne - Geek
Tom Chichester
Ruth summersides
Are you a Cat Expert? Answer questions, earn points and help others
