Computers & Internet Logo
Question about HP Computers & Internet
How do i get the computer to come out of power save
Wont come on at all. i turn the monitor on and off and it just says hit any key on keyboard or move the mouse. I do both and nothing happens with either
Posted by debbie hibbert on
Banjade
  • 430 Answers
1. Swiched CPU power off (But Monitor on - though blank )
2. Removed motherboard battery(its like a watch battery but quite bigger)
3. Then Swiched th CPU on
4. On screen message ( the I pressed F1 on the keyboard) .
now see what happen.
Posted on Aug 15, 2012
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: LG Flatron monitor remains in Power Saving Mode
Sounds like an issue with a memory card or pci card not properly in place. Try opening up the sytem, then make sure each card is properly inputted in it's slot. This may cause the the monitor to show power saving mode especially if the memory is not properly placed.
Thanks
Posted on Nov 21, 2007
Anonymous
  • 68 Answers
SOURCE: Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Posted on Oct 30, 2008
Anonymous
  • 23 Answers
SOURCE: My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Posted on Jan 24, 2009
Anonymous
  • 1605 Answers
SOURCE: power save mode turns on while I'm still on the computer.
check the BIOS setting
Posted on May 27, 2009
Anonymous
  • 33 Answers
VIRUS
Posted on May 28, 2009
Hi I have a toshiba satellite L455D S5976 It just stopped working will not turn on but its got power I connected a monitor usung rgb cable and its got a yellow saying its in power save mode and to hit a...
you should probably get a new screen fixed to laptop, because until u log in and system boots up properly, second screen will not work,
as u tried turning of laptop forcefully, advance boot options must be up on computer, hence not displaying.
There is a long silver button with a black moon on the upper left of my keyboard. When I accidentally hit it, the screen goes black. What is it.....and how do you get your screen back?
Depending on how your keyboard is configured, that key is set to do one of two things:
  1. Puts your computer to sleep. (A low power state where almost everything is shut off, including the monitor). You can resume from sleep by hitting any key on the keyboard, hitting the power button on your computer, or clicking the mouse.
  2. Puts your computer into hibernation. (An even lower power state where everything is actually shut off, but a copy of everything open is saved to the hard drive to be opened during start up. It basically allows you to turn off the computer, but be able to turn it back on with program exactly how you left it). You can resume from hibernation only by hitting the power button on your computer.
Hope this helps. If it does, please accept and rate the solution! You can leave a testimonial or contact me with any more questions you may have. Thanks for using FixYa!
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
2answers
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Monitor on power save mode and using wireless keyboard and mouse
This sounds like the monitor is not reading a signal from the computer. I had the same problem when I installed a DIV cable from my old VGA cable. The video card was still sending the signal via VGA port instead of the DVI port of my video card. You should cheack the cable to you're computer and what port is being used. If everything is hooked up correctly then there might be a problem with the cable. Other then that it could be you're video card. If the hard drive is running and everything is running fine then what I said should be whats wrong. If nothing works go back to the shope and tell them the new problem you have.
1helpful
3answers
How to turn the monitor off?
go to control Panel, Hardware and Sound and then select Power Options. There are several plans to choose from or you can create your own Power Plan. Choose when you want the display to shut off but make sure the "Put the computer to sleep:" is set to "never". The save the changes.
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
1helpful
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Monitor in Power Save Mode
The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
2answers
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
