SOURCE: Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
SOURCE: My Sony KDP-51WS550 wont turn on anymore. The
Type in space bar Understanding sony Blinking codes this will take you to a website telling you what each code means.
SOURCE: Sony Wega SXRD60 - standby light blinking - tv won't turn on
Standby Light flashing. Can get sound but no picture.
SOURCE: my sony KDP-51WS550 tv has no picture, only sound,
The problem is from the lamp of the television, it is about to develop a fault that is why the picture goes off but you have sound.
The 10 blinks you see on the led is a symbol that the television is having a fault that needs to be checked.
The solution is for you to open up the television and locate the lamp and replace it with a new one, once you replace the lamp, the television will be in good condition once again.
Take care and good luck
SOURCE: My Sony KDP-51WS550 will come
Hi Kimber, Hope I helped you. Thanks for using Fixya
The main reasons of your problem is the bulb which is
already faulty to its end. The unit will automatically shuts off when it sense a
bulb failure. But before you replace the bulb I would advice you to work first
on itspower supply. Look for open
fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms
like what it showing now. If you don't have necessary tools
and test instruments, and can't do the job yourself, I would advice you to
look for a professional to
troubleshoot the problem. Don't attempt to work in the power supply if you
don't know the safety precaution of
handling it, there some stored electricity enough to hurt you with
a little mistake only.
Have a nice day!
Hi Kimber,
Hope I helped you.
Have a nice day!
