My fuse blew and im trying to get a replacment one just dont know what one i need
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
SOURCE: Enermax EG495P-VE (Off warranty) will run for 1
It's probably an accumulation of lint, dust, pollen, and anything else in the air over time, if you're lucky. This isn't the easiest of things to do, but you will have to use a small brush for a lot of clingy stuff, to compressed air for most cases. It could be a slight short in the fan motors, or a bad electrical connection or connector that's causing the current to rise and trip a thermister, or other heat sensing device. I would take it apart and see what I could see. Most of the time it's something simple, never know till you look.
One thing...if you do find an overload switch or circuit, figure out the problem that's making it overload. It's probably not the switch that's bad, but something else. Good luck!
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
