Question about GE A730 Digital Camera
It is reading Lens Error how to fix
It is 3x optical zoom 6.4-19.2mm 1:3.5-4.3
  • GE Master
  • 17,970 Answers
Hi there:
I suggest check in this link, some tips about fixing-lens-error-on-digital-camera.
Hope helps.
Posted on Aug 15, 2012
Transfer pictures from 813 3X optical zoom Camera to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 16, 2012 | Kodak Easyshare C813 8.2 Mp 3x Optical...
Zoom is very poor, however a family friend has the same model but seems to have an ''extended'' zoom. Is this a setting that ive missed or is the camera faulty??
The extended zoom you mention is possibly the Digital zoom.
A lot of point and shoot compact digital cameras have a basic 3x optical zoom and 3x digital zoom.... though picture quality will deteriorate once you enter the digital zoom areas.
Hope this helps.
Jan 11, 2010 | Cameras
I'm having problems with I focus the camera out. It becomes burrie
The camera has limited ability to zoom out. I believe you have a 3x optical zoom, and a 7 x digital zoom. Once you go beyond the optical zoom, the camera attempts to digitally render the zoom which can cause pixalation, or bluriness. This should never be an issue inside the optical zoom range as the image is going directly through the lens.
Dec 19, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Just purchased it from bid tv it has 4xdigital zoom would i have been better to get optical zoom instead this is my first camera
Digital zoom enlarges the ccd image and will become more pixelated the more you zoom and optical zoom uses an actual lens to magnify the image coming into the camera. optical zoom is better than digital zoom.
Sep 25, 2009 | Vivitar 7.0MP Camera Digital Camera with...
Optical zoom
Hey needacamera,
The range of an optical zoom lens refers to how wide angle to telephoto the lens covers. An example of a 6x optical zoom would be an 18mm-108mm lens, which covers wide angle to telephoto. An example of a 3x zoom lens would be an 18mm-54mm lens, which would provide a capability of capturing images from wide angle to normal views. To calculate the x factor of an optical zoom you would divide the largest number by the smallest number on your zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 31, 2008 | Cameras
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera) Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Telephoto zoom
The D-565 camera has a 4x digital zoom, in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Telephoto zoom
The D-575 Zoom has a 3x digital zoom and a 3.3x digital zoom, which gives you a total zoom of 10x. Use the shooting mode menu to activate the digital zoom feature. The D-575 camera has a 3.3 digital zoom, which gives you a total of 10x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Options for more telephoto zoom
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
GE A730 Digital Camera Logo
Top GE Cameras Experts
Jeffrey Groves
Jeffrey Groves
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
