Question about Frigidaire PLEB27T9DC Electric Double Oven
Need control for frigidiare upper oven model rbe-97n
Deluxe double oven . upper oven control , includes thermostat ,one complete unit part # D-64042
Posted by JAMES GILLENTINE on
1 Related Answer
Anonymous
  • 65 Answers
SOURCE: I have a frigidaire double convection oven. The
whoever you brought it from get your money back
Posted on Dec 25, 2010
My RBE-94N broiler element will not heat the light on front come on but no boiler the bottom baking element works
Just replace the upper element if you see a break or bulge in it. Also check the spade connection on it at the rear as they can arc and burn out.
Frigidaire Range Stove Oven Model RBE 94N RBE94N RBE 94N Heating Element...
Jul 24, 2018 | Ovens
The heating element on my Frigidaire RBE-97N has cracked and broken. How easy or hard is it to replace it?
I assume it is the bake element. These are very easy to replace. make sure the power is off and you can access the screws from the oven cavity. remove the screws, pull gently on the element. If the wires are long enough you should be able to disconnect them or unscrew the wires from the terminals. reattach the wires to the new element. reinsert it back in place and there you go.
Nov 24, 2013 | Frigidaire Ovens
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Old frigidaire wall oven model RBE-94N emitting strong odor & not baking
Hello - From what you have described it sounds like the unit has faulty elements or could possibly be experiencing a wiring issue with the EOC. Try resetting the oven by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately to properly diagnose the unit.
Nov 10, 2012 | Frigidaire Ovens
I used the self-cleaning feature and now my oven will not turn back on.
Their is a high limit thermostat that has tripped,on older model and on some newer models it has a red button on it that can be pushed in to reset it.Other times once it goes out it must be replaced.
For the upper oven its behind the control panel,for the lower its behind the grill between upper and lower oven
I hope this helps you to understand why your oven wont heat,
Gene
Aug 05, 2011 | KitchenAid Architect KEBS207S Electric...
Double wall oven: Model JKP26GOP13G. The upper oven heats but not up to the setting input. If setting is 350 F, for example, the stove only gets to around 200F.
I trust the door is sealed correctly. If heat is escaping this could be the problem. If the seal is okay the only thing it could be is the oven thermostat controller. It sounds like it is faulty and needs replacing.
Feb 12, 2011 | GE Ovens
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
The upper oven door is locked shut and will not release. All lights are off on the display panel and the oven does not respond when any setting are pushed. I have reset the circuit breaker several times...
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
Jul 09, 2008 | Whirlpool RBD245PDS Electric Double Oven
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at [email protected]
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire PLEB27T9DC Electric Double Oven Logo
178 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
