The tractor is quite new this year and the drive belt keeps coming off the pulleys. Belt does not seem broken or compromised. Have put it back on several times, but continues to come off the pulleys and seems too loose. Do I need a new belt or are there any other adjustments I can make to tighten the fit and keep it on the pulleys?
SOURCE: I need to put a blade belt back on my Craftsman yard tractor
If you disengage the Blades like you normally would, this will give you plenty of slack in the belt to put back on. There should be a pulley or lever that tensions the belt when it is engaged and that is what is causing it to be too tight to put back on. Hope this helps
SOURCE: JD mower L110, hydro drive. Reverse power is low.
i have the same thing a tractor shop told me thats ok they are slowed dowm for saftey
