Question about Samsung Digimax S500 Digital Camera
My card is locked on samsung E570 how do i unlock
My SD card is locked on my samsung E570 how do i unlock
Posted by Diane Bettridge on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Aug 14, 2012
2 Related Answers
Anonymous
  • 26 Answers
SOURCE: memory card is locked
There is a small tab (like a very small hole with a sliding piece of plastic) on the corner of the memory card. Slide it to unlock it :)
Posted on Dec 17, 2007
InPlainEnglish
Jan Rainone
  • 137 Answers
SOURCE: i have a samsung digimax
Check with Samsung Support if this doesn't work, I went through the entire site, at least 6 people ask the question but 0 answers, is the message next to every single one of them:
Try formatting the disk Inside The Camera, first.....
You can Chat Live Here
Posted on Mar 20, 2011
How to unlock sd memory card ,the camera tells me card locked
Unlock sim for samsung E-570
To unlock Samsung SGH E570 model phone use unlock code.Visit the site Unlock-zone.com get unlock code at low cost and unlock from service provider lock easily.Then use with other GSM network sim card in it.
How to unlock camera samsung ES30 2gb sd card
SD and Mini SD memory cards SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Dec 26, 2012 • Cameras
1helpful
2answers
Card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Necesito el codigo de desbloqueo del celular samsung shg e570
Hi you can try Simpleunlocking.com to get unlock code for your Samsung SGH-E570 and get it unlocked from Movistar and you will be free to use other provider's SIM in your unlocked mobile..
2answers
It's a samsung T mobile SGH-E570. It was given to me as a gift, it is red in colour. It requires sim lock.
it may be due to network lock, contact service provider if it locked , you can get unlock codes here http://www.theunlockarena.com/supported-phones/rs13wp7/
you need to specify the country and network provider,
check, if your model is available in the list
7helpful
4answers
Unlock codes fro samsung e570
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
2answers
Card Locked
you have to use the origanal samsung chip try samsung.com
Forgotten pin
ring up your costumer services and conferm to them that is your phone and you have for got your pin and they will hope fully change your pin and give you a new one or tell you your old one
2helpful
Keypad lock
You cant lock the keypad of an sgh e570 it is locked as soon as you close the flip on the phone
Samsung Digimax S500 Digital Camera Logo
Top Samsung Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Samsung Camera Expert? Answer questions, earn points and help others
