Question about Jacuzzi Submersible Pump, 12 Gpm 3/4 Hp 2 Wire
Need wiring schematitic for Jacuzzi deep well submersible pump Model# S410-8PV
It's called a Sand Handler....there is a plug that goes into the motor from the outside of it that goes in only one way. There is a green wire(GND) and 2 black wires (not marked in any way). The motor itself is sealed by machine and cannot be opened to check that side of the wiring connection.
Posted by Patrick Serle on
2 Related Answers
Anonymous
  • 34 Answers
SOURCE: I have a jacuzzi 1/2 hp submersible well pump.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Posted on Jul 03, 2009
gotgeek2
Bob
  • 565 Answers
SOURCE: We recently bought a second
I tried to find the Astra Padova Venus 1000 model without any luck.
All motors have a nameplate. It is either metal or a sticker. If you can provide the manufacturer, cat # and/or part number from the nameplate on the _pump_ motor we should be able to look it up.
The nameplate will look like this: http://www.google.com/imgres?imgurl=http://www.poolcenter.com/images/centmagnameplate.jpg&imgrefurl=http://www.poolcenter.com/pumps.htm&usg=__uOeUWPwZjFnmO8F2KNl3n-k3GIM=&h=417&w=488&sz=32&hl=en&start=15&zoom=1&tbnid=cSU5ie-8i0stWM:&tbnh=123&tbnw=155&ei=NCHCTc-2OYXB8QPY67zbBQ&prev=/search%3Fq%3Dmotor%2Bnameplate%2Band%2Bdiagram%26hl%3Den%26sa%3DG%26biw%3D974%26bih%3D574%26gbv%3D2%26site%3Dsearch%26tbm%3Disch0%2C603&itbs=1&iact=hc&vpx=122&vpy=222&dur=1346&hovh=207&hovw=243&tx=120&ty=125&page=2&ndsp=15&ved=1t:429,r:10,s:15&biw=974&bih=574
or this: http://www.google.com/imgres?imgurl=http://cr4.globalspec.com/Postimages/200806/plate_8FFEC316-C1AD-E7D4-12F4D8893E3B3351.jpg&imgrefurl=http://cr4.globalspec.com/thread/22534&usg=__xoRIlDqFgJKXrzCEZMK9inJ8mco=&h=400&w=300&sz=43&hl=en&start=60&zoom=0&tbnid=F7ZNda5M1zMivM:&tbnh=124&tbnw=93&ei=kCPCTcHDLMq48gO-0fDMBQ&prev=/search%3Fq%3Dmotor%2Bnameplate%2Band%2Bdiagram%26hl%3Den%26sa%3DG%26biw%3D974%26bih%3D574%26gbv%3D2%26site%3Dsearch%26tbm%3Disch0%2C1486&itbs=1&iact=hc&vpx=658&vpy=339&dur=1287&hovh=124&hovw=93&tx=79&ty=107&page=5&ndsp=16&ved=1t:429,r:3,s:60&biw=974&bih=574
Many times the wiring diagram for the motor is on the motor nameplate. Also, look on the reverse side of the cover for the connection box on the pump motor, as sometimes that's where one will find the wiring diagram for the motor.
Posted on May 05, 2011
Any suggestions when a newly installed utilitech pump won't turn off?
its sucking dry or your wiring is not right, or of course an airleak, or the prime is not good, did you fill the pump prime hole at the 3/4 plug on bottom.of pump, deep well pump do you mean submersible? if so and it is a deep well submersible there is a prime, its got to be an airleak in the line or the pressure tank is not pressured up to the specs, and the gauge
May 16, 2015 | Jet Plumbing
How do I troubleshoot a Simer 3/4 hp submersible deep well pump
Check power at well head. then turn power off and disconnect wire nuts. check continuity on leads to motor should read about 500,000. Check each lead to ground for shorts.
Oct 14, 2014 | Simer 2873G Submersible 4" Well Pump,...
Jacuzzi 470 Model has '- - - - ' problem code on display.
This is called a watchdog. A number of situations can cause this situation. Check your "Sensor Plug", ensure good tight connection. Air locks not necessarily the problem, but if in the "Circulation" pump, it may. Your Circ pump may have unfortunately failed. Can you tell if it is actually pumping a good amount of water through its return fitting? If not, then either an air lock or it failed.
Dec 27, 2012 | Pool & Spa
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
Jul 18, 2012 | Goodman Heating & Cooling
I do have inground pool 16 *32 10 feet deep at one end and 4 feet at front, The pump did not start at all when i started it. Since the pump is an old pump above 15 years old I decided I would buy a new...
I'd suggest the 1.5 HP Hayward Super Pump, model SP2610X15. It's layout makes fitting it into the footprint of the Jacuzzi easier since it's ports roughly line up and are smaller in spread than the jacuzzi. Any pump will require some monor replumbing; the Haywards should be the least intrusive.
Another good choice would be the Pentair Whisperflow in a 1.5HP with or without the variable spped features.
John
May 01, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Tech moved 5hp Jacuzzi submersible pump to new well and lost color code.(red,blk,yel) Can I measure resiastancde between wires from pump to determine color code to hook up to the controller?
Measure the resistance between the 3 leads:
Wire 1 to 2, wire 2 to 3, wire 3 to 1.
Find the highest reading. The lead not used in this highest reading is
the yellow lead.
Now use the yellow lead & measure to the other 2 wires.
The higher reading will be the red lead.
The lower reading will be the black lead.
Aug 04, 2009 | Plumbing
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
Jacuzzi Submersible Pump, 12 Gpm 3/4 Hp 2 Wire Logo
281 people viewed this question
Top Jacuzzi Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
